Puch Ignition coil in Cimatti
Justin Brownell /
I purchased a Puch ignition coil for my cimmatti city bike. I asked if it would work, on here. And sounded like it would. Just double checking again if it will.
Also the coil off of the puch came with two seperate wires. mine has one wire and the ground. (the two wires may be together in the protection sleeve haha can't think of another word). What are these other wires for off of the puch coil? should I just be able to solder them together with the old wires.
thanks
Justin
Re: Puch Ignition coil in Cimatti
the puch ignition coil has 2 wires one is stamped with a #1 and the other is a #15. The #1 is the hot wire and the #15 is a ground. thanks Raymond
Justin Brownell /
thank you im goign to work on that today.
