Pedal crank removal
Dave /
I finally found a decent eplacement pedal/crank set for my Maxi 1-speed. It's the version where the left crank is welded to the sprocket end and the right crank is held in place with a pin.
I'm having trouble removing the crank pin from the right side.
Is there a trick to this? I can't tell if it screws in or not and I don't find anything about removing cranks in the service manual (odd).
Thanks.
