Re: Lots of Tomos Problems
Don Pflueger /
what year lx? how many miles? how much compression does it have?
my first clue as to what your pribkem may be is that you have a bi-turbo exhaust, but you fail to mention whether or not the carb was upjetted. so, how many miles were put on this bike after the exhaust was installed? and what jet size are you using? this time of year, the air is cold and getting dense which means the engine runs leaner. and if it was never upjetted, you are running dangerously lean.
get some compression numbers. everything you have described relates to a worn piston and rings due to the fact that it has been running too lean.
as far as the gas dripping, that may be from the loss of compression and the engine not compressing the fuel/air mix correctly and burning off all the fuel. or the needle and seat in the carb are worn out and its leaking into the cylinder. or the plug could be bad as joe mentioned.
one thing you might want to check if your bike is 1997 or newer is the intake manifold bolts. they are prone to coming loose. and if so, would explain the hard starting as well.
so get the numbers i asked about and lets work from there.
  Lots of Tomos ProblemsTopic by: Red Larsen Red Larsen 11/30/04 09:05PM
  Re: Lots of Tomos ProblemsRe: Ryan Nealy Ryan Nealy 11/30/04 09:30PM
  Re: Lots of Tomos ProblemsRe: Timmy Southpark Timmy Southpark 11/30/04 09:32PM
  Re: Lots of Tomos ProblemsRe: Joe Woods Joe Woods 11/30/04 09:37PM
  Re: Lots of Tomos ProblemsRe: Don Pflueger Don Pflueger 11/30/04 10:16PM
  Re: Lots of Tomos ProblemsRe: Joe Woods Joe Woods 11/30/04 10:29PM
  Re: Lots of Tomos ProblemsRe: Don Pflueger Don Pflueger 11/30/04 10:34PM
  Re: Lots of Tomos ProblemsRe: Dave Mcgarry Dave Mcgarry 11/30/04 10:38PM
  Re: Lots of Tomos ProblemsRe: Red Larsen Red Larsen 11/30/04 11:20PM
  Re: Lots of Tomos ProblemsRe: Don Pflueger Don Pflueger 12/01/04 08:30AM
  Re: Lots of Tomos ProblemsRe: Timmy Southpark Timmy Southpark 12/01/04 12:33PM
  Re: Lots of Tomos ProblemsRe: Red Larsen Red Larsen 12/01/04 01:56PM
  Re: Lots of Tomos ProblemsRe: Timmy Southpark Timmy Southpark 12/01/04 02:01PM
  Re: Lots of Tomos ProblemsRe: Don Pflueger Don Pflueger 12/01/04 03:01PM
  Re: Lots of Tomos ProblemsRe: Don Pflueger Don Pflueger 12/01/04 02:57PM
  Re: Lots of Tomos ProblemsRe: Harry Howlett Harry Howlett 12/01/04 07:40PM
  Re: Lots of Tomos ProblemsRe: Harry Howlett Harry Howlett 12/02/04 08:10PM
  Re: Lots of Tomos ProblemsRe: Ryan Nealy Ryan Nealy 12/02/04 08:34PM
  Re: Lots of Tomos ProblemsRe: Nero Nero 12/05/04 12:55AM
  Re: Lots of Tomos ProblemsRe: Danny Emerson Danny Emerson 12/05/04 06:17PM
