Re: Need help, cant find problem- tomos
Don Ohio /
Sorry............if you are SURE you installed the piston CORRECTLY(usually arrow down toward exhaust) and you have put an induction timing light on it and checked for spark thru the plug, and the gas is getting thru the carb to wet the spark plug AND YOU HAVE AT LEAST 100 LBS. OF COMPRESSION and you KNOW the crankseals aren't blown allowing outside air to weaken any fuel mixture..............then I can't suggest a problem. don-ohio (:^)
