Mid-range bogg
Hey, i just got a General 3star from a buddy, and it has a mid-range bogg in it. But it runs great on top end and low end. Any tunning tips or anything to get this thing to actually run sufficiently would be helpfull.
Aaron
Re: Mid-range bogg
look for any and all air leaks,spray the carb with carb cleaner with the eng running, if there is any drop in RPM you got a leak, this is just a rule of thumb or a place to start, good luck
Re: Mid-range bogg
Jason Luther /
what kind of carb does it have?
Re: Mid-range bogg
I found out what the problem was. I jsut took the carb completely apart and sure enough, there was some crap plugging up the main jet. thanks for you effort guys.
