Re: Speedo doesnt work
Aaron Colley /
Alls you need to do to check to see what the problem is, is take the speedometer cable out of the wheel thing, and rotate the inside of the cable with a drill and see if the speedometer works. And if that doesn't work, take the cable off completely and see if both ends will rotate when you turn the one side. It could just be a problem with the cable, or the thing down by the wheel.
