Transmission fluid
Time to change the fluid in my Maxi. It uses type 'F'. Anyone recommended a particular product?
Re: Transmission fluid
is this a one speed you have? I was curious as to what atf the 1 and 2 speeds use. thanks.
It's for a 2-speed.
Pretty sure they all use type F, i think you might be able to put dex3 in them in a pinch but i'm not sure. Mineral ATF is pretty much all the same, i run casterol but it doesnt really matter.
Yeah, type F. I never bought ATF before (I drive cars with manual transmissions or automatics that can't be serviced by the owner, uggh) - didn't realize this type was that common.
Changed the fluid on the Maxi today. Seems to run a bit better.
