Re: Help on a '75 Puch Maxi-S custom
Ray West /
The manual probably says 48Kmh, which is approx 30mph, there is no decopression lever, unless you have some bike I have never heard of, there is a starter clutch lever, and that can be adjusted tighter on one or two speed bikes.
There are several things that could be wrong with the bike, check out freds guide in the resources section above, it should help you out, but a couple things could be carbon build-up, or it needs new rings
