Re: Can your ped go the distance?
Ja'Far Rogers /
This is a message for Patch, you need to DERESTRICT your moped if you want it over 50mph my friend. If you still have your original exhaust either get rid of it and get a performance type or simply unbolt it and remove the washer inside, also there's a backplate that is attached to your clutch that you can safely remove _if you know what you are doing_ . after that you'll notice an increase in power, not like WOW but good enough.
