Re: Polini/V1 ticking diagnosis
Joe Woods /
As i read this thread i wondered what kind of shape was the bottom end in just before the kit? Did you blow or seize a piston or did something else happen? Maybe it just has lots of miles on it?
When you double the power of an engine the force on the bearings is multiplied by four time. So, unless your bearings were in perfect shape before the kit you might be listening to bearing damage/slop that already existed before the kit but was unnoticable.
One way to check is to remove the head, bolt the cylinder back down..
Turn the piston around and just slightly beyond TDC. (At this point the crank/rod/piston are 'stretched out' )
Now hit the top of the piston with the heel of your hand. If you hear a "click" you are listening to excess bearing clearance somewhere in the bottom end..
  Polini/V1 ticking diagnosisTopic by: Patrick Turner Patrick Turner 11/18/04 09:26PM
  Re: Polini/V1 ticking diagnosisRe: Bryan k Bryan k 11/18/04 10:46PM
  Re: Polini/V1 ticking diagnosisRe: Cpt. F. Cpt. F. 11/19/04 02:32AM
  Re: Polini/V1 ticking diagnosisRe: Patrick Turner Patrick Turner 11/19/04 02:35AM
  Re: Polini/V1 ticking diagnosisRe: Cpt. F. Cpt. F. 11/19/04 03:47AM
  Re: Polini/V1 ticking diagnosisRe: Patrick Turner Patrick Turner 11/19/04 04:35AM
  Re: Polini/V1 ticking diagnosisRe: Bryan k Bryan k 11/19/04 11:52AM
  Re: Polini/V1 ticking diagnosisRe: Cpt. F. Cpt. F. 11/19/04 12:12PM
  Re: Polini/V1 ticking diagnosisRe: Mo Peds Mo Peds 11/19/04 05:07AM
  Re: Polini/V1 ticking diagnosisRe: Patrick Turner Patrick Turner 11/19/04 01:11PM
  Re: Polini/V1 ticking diagnosisRe: Patrick Turner Patrick Turner 11/20/04 04:03PM
  Re: Polini/V1 ticking diagnosisRe: Fede Berkelaar Fede Berkelaar 11/21/04 08:46PM
  Re: Polini/V1 ticking diagnosisRe: Patrick Turner Patrick Turner 11/21/04 10:44PM
  Re: Polini/V1 ticking diagnosisRe: Don Ohio Don Ohio 11/22/04 09:29PM
  Re: Polini/V1 ticking diagnosisRe: Bryan k Bryan k 11/22/04 09:55PM
  Re: Polini/V1 ticking diagnosisRe: Patrick Turner Patrick Turner 11/23/04 08:47PM
  Re: Polini/V1 ticking diagnosisRe: Xxxxxxx Xxxxxxx Xxxxxxx Xxxxxxx 11/23/04 11:34PM
  Re: Polini/V1 ticking diagnosisRe: Cpt. F. Cpt. F. 11/24/04 05:08AM
  Re: Polini/V1 ticking diagnosisRe: Dave Mcgarry Dave Mcgarry 11/24/04 09:48AM
  Re: Polini/V1 ticking diagnosisRe: Cpt. F. Cpt. F. 11/24/04 11:03PM
  Re: Polini/V1 ticking diagnosisRe: Patrick Turner Patrick Turner 11/24/04 11:34PM
  Re: Polini/V1 ticking diagnosisRe: Ben Van Zoest Ben Van Zoest 11/25/04 02:02AM
  Re: Polini/V1 ticking diagnosisRe: Patrick Turner Patrick Turner 11/26/04 12:51PM
  Re: Polini/V1 ticking diagnosisRe: Ben Van Zoest Ben Van Zoest 11/27/04 12:31AM
  Re: Polini/V1 ticking diagnosisRe: Joe Woods Joe Woods 11/26/04 07:09PM
  Re: Polini/V1 ticking diagnosisRe: Patrick Turner Patrick Turner 11/27/04 05:57PM
