honda pa 50 variator
Leonard Torres /
I bought a spare engine for my pa 50 and was about to install it when I ran into problems.I cannot get the second half of the variator off the shaft.I do not have a manual.Do I need a special puller to get it off? The first half came off easy by removing a nut and sliding off the shaft.Can any one help please me?
Re: honda pa 50 variator
I have the manual. It shows a small nut down in the center of the hollow fixed hub half. After you get the small nut off the hub should come off the crankshaft end. You might have to use a puller if the hub is rusted on.
If you have a fax machine I can fax the pages to you.
Leonard Torres /
Thank you for your reply.My work fax is 1-360-354-5355, Attention Leonard Torres.I was able to remove the nut in the hollow area of the shaft, but 2nd half will not come or slide off.It has a reverse thread on the front of it too for some reason.
