Re: Moped wont idle ive tried everything
Marshall Lewis /
If you have cleaned the carb, try adjusting the timing there are posts and articles on this just do a search. Pull and push your cables around and make shure there is no kink tighten or losen the cable adjuster on the carb top. It might be your petcock (the on of valve) when the fuel line is detached gas should pour or stream out, if it trickles or drips then you have a problem there.
hope this helpes, Puchs are the best mopeds keep at it you will get it.
