How long is too long for intake manifolds?
Matthew Westberg /
as the Topic says: How long is too long for a replacement intake manifold?
The stock manifold on my ped is about a half inch long, not very long at all! With a pipe several inches long I know it'll affect performance, but how long is too long for a manifold? When and how exactly might it affect performance?
Re: How long is too long for intake manifolds?
I had some one at a performance shop give me this tip. They said start long, in your case maybe a couple of inches, run your bike, then cut off a little bit at a time and keep testing. Once you determine which length worked best, you can make a permanent one at that length. Good luck.
