Re: Now I've Done it
Matt Brown /
Okay time for the final solution. Get a small metal bit and drill right down the center of the screw aways (1/4 in). Then get a screw removal bit...looks like a dull, twisted bit with a tiny square tip. Screw that into the hole you drilled (I think with the bit turning counterclockwise) and as it goes in the screw comes out. A must have set of bits for any mechanic. There you have it.
Mojo figured all this out on his own...I'm just posting it for all to know.
