Avanti Autopower-No spark
Paul Jansen /
I have an Avanti Autopower that all of a sudden quit running.
As far as I can tell, there is no spark. A new spark plug has been installed. All the wiring harness
plugs have been checked and double checked. The ignition
switch has been taken apart and checked for corrosion. The magneto is working(headlight lights when being cranked).
How can I check the CDI ignition? Is there anything else I can
check(regulator)? Thank you for the time and replies.
Re: Avanti Autopower-No spark
Check if your carb jet is clean. Or are you positive it's getting no spark?
Paul Jansen /
Oh, I should have mentioned that I also cleaned the carburetor. I have checked for spark by holding the plug against the cylinder head while cranking. I must admit that I am stumped.
