WHATS A BATTERY EXHAUST FOR?
THERES A LITTLE PLUG TO SLIDE ON A VIHNYL TUBE.....ITS CALLED A BATTERY EXHAUST.....its like 1 1/2ft long tube, do i keep it on even wen its installed on my fa50?
Re: WHATS A BATTERY EXHAUST FOR?
Edward Edwards /
Keep it on, it's also called a vent. It directs the acid fluid from your battery ( because of bumpy rideing conditions) safely away so your paint and you are not harmed.
Leave it on.
It is a breather tube.
As the battery is discharged and then re-charged various gasses are generated and need to be vented.
Run the tube straight down. Do not have any dips in it a liquid will collect in the low spot and prevent the battery from breathing.
https://www.mopedarmy.com/forums/discuss/read.php?f=1&i=166233&t=165977
This was covered pretty well in your other post.
