Tomos Speedo light problem?
The light on for my speedometer doesn't work. I took it out and it looks good; the filaments are still intact.
I have follwed gray wire (speedo-light) down to where it connects to a big plug-in. Then it goes from here to the back.
All other lights work ok.
How do I use a multi-meter to check if my moped is getting current to where the bulb goes into the buld holder?
What two points should I put the mult-meter to, and what should be the multi-meter settings?
What and where else should I check?
Thanks everyone for your intelligence.
Re: Tomos Speedo light problem?
OK if you have a volt meter, then you put it on the ohms setting i think, then it dont matter what prongs youput them on, but it should light up or display something. You can also hook up a six volt battery to it with wires from the sprngs to ur light to check it.
