cable problems
Troy Brown /
every time i change my carb setup ,the cables become frayed at the ends . can i braze or solder the ends to keep them from fraying (same thing with my clutch cable) i tried to cut them with wire cutters, but the cut flattens the cable, making it to big to fit in the holes, always leaving 1 or 2 strands on the outside when i pull the cable through. i end up having to snip the strands . what the secret?
