Re: HELP MY FA50 WONT START BUT I FOLOWed FREDS GU
Zach S /
mufflers off, air filters off....it was running before the piston got stuck.......im measuring mine with a automotive pressure gauge....,could it be the fuel and idle screws? does anybody know about that on the fa50?......it may be compression...cause before the incident with the piston getting stuck in the cylinder....i do have another cylinder on the way.... there are to scratches about 2 1/2 inches long on each side of the cylinder from the back to the front....so do you think the cylinder is the problem? even if i have a good spark, i dont think it will even fire that spoonful of gas i put under the spark-plug hole...., sp which is it.... the spark-plug,fuel and idle screws, or the scraped cylinder?
