if ne one can has or can find a rebuild kit or a carburetor for my 1981 Indian Moped or that has a 49CC carb that u might think would work for the engine it would do great help thanks alot....
Bryan
586-610-3766
Bryan
586-610-3766
I think those take the standard Dellorto 14.12. They're very easy to come by. I'll sell you one. $25.
BK
I have seen many carbs on indians, but never the same one twice, and never a dellorto. They are usually mikuni.
Ooops. I thought they had Dellortos on them. I have a 17mm Mikuni if you're interested in that.
BK
yea if that will work all i did was strip the heads to the idle screw an mixture screw
I'll double check it tonight and make it's a good carb and e-mail you.
I pesonally dislike the makuni carbs that are on the indians. I took mine off and used a bing 1/15/27 carb. It mounted perfectly to the maifold. The reason why i dislike the makuni carb is its frustrating to hold the comression release and choke and give gas at the same time. I would rather have a manual choke on that moped.
If BK is offereing that carb for 25 bucks you should nab it if you dont mind the setup.
Also a good source for indian parts is bobs marine sales.
~Ben~
The dellorto is $25. I don't remember how much the Mikuni is.
yea i know there junk everytime i get it runnin something goes wrong with the carb..
id be interested in the 17 mm just email me an let me know the details
