I had to clean mine three times before it ran right. I read awhile back that FA50s are particularly sensitive to dirty carbs. The fuel pump in the petcock assembly is vacuum operated. You might put an in-line fuel filter on at some time after you get it cleaned up. Did you check for a vacuum leak at the carb? Use search function if you aren't sure how to do it.
