ok checked a few things
Jason D /
i took the carb apart cleaned it and set the idle, still it bogs down the same as before. The more throttle you give it the worse it sounds. I took off the pipe and it ran even crappier, loud as sin tho. I drained the automatic tranny fluid. I think I have some 75w 90 gear oil. Would that work in the gear box? Ill check the timing but I have no idea how on this thing, anybody know? Damn its frustrating
