Re: DUDE THIS IS URGENT> I NEED YA"LLS HEL
Jason Luther /
try to compress the rings as you slide the piston out. if worst comes to worst (and they are easily gotten) grab the ring with pliers and break it (it should be pretty easy), then you should be able to compress it enough to get it out. a $10 swet or ring is cheaper than a wreched cylinder.
