Vespa Grande keeps burning out tail light bulbs
every time I replace the tail light bulb the filament for the tail light burns out the brake light does'nt so the problem is with the running light. I am using a 1154 GE bulb any ideas??
Re: Vespa Grande keeps burning out tail light bulb
I have an electrical background but my moped knowledge is limited.
Sounds like you need to add a resister and or an on off switch for nightime use only.
Rob
Do you ride down steep hills at top speed?
occasionally, its something I had'nt considered, would adding a resistor help? or would that make the light dim?
