Re: Removing axle/greasing bearings Puch Mag
David Williams /
I've got a 78' Maxi and I sort of did the same thing... a while ago one of my rear wheel bearings dissintegrated and ruined the axle too. I ended up buying a used wheel on eBay from a 79' Newport. Mine was easy to take apart though. Just remove the bearing nut on one side and pull the axle out. Degreased everything with some break parts cleaner and regreased all the bearings etc. Runs smooth as hell now. :-D
