Re: Removing axle/greasing bearings Puch Mag
Brett Walker /
did you tighten it up at all, because my axle is really loose and moves around and when you spin it its really loud, there is a sort of nut on the end which i assume needs to be loosened with the speacial wrench, i ve been told that the mags have a sort of sealed bearing that needs to be tightened with a bearing wrench, i am actually really confused about what to do with mine, i have never had to replace a bearing,
