Re: Hard to start still
Cj Phillips /
once the bike starts up with the choke, its best to then turn it off by pulling the throttle all the way back. if the choke doesnt move then follow the other guys intructions. if it does totally get stuck you can take off the airfilter at the carb and there is a really small metal tab you can push in. its hard to explain exactly where it is. that will pop the choke back to the off position.
