Re: tomos help
Don Pflueger /
.014"-.016" is usually the standard for most peds. your engine probably wont run at all withouta base gasket. and just cuz the rings look good does not mean a thing. you cant see how muchoverall surfacearea of the ring is worn away. the best you can do is insert the rings in the middle of the bore and measure the rings end gap with a feeler gauge. i would say any gap bigger than .004"-.006" is worn out.
