Re: Maxi air cleaner
Graham Motzing /
My '78 newport L (2hp) has the sides of the case apparently welded together. Should i cut it apart, or does it need to be replaced as a unit. And what else would work as a replacement. I know some peds use the filter as a restrictor for more low end, do puch's?
