Maxi air cleaner
The service manual for the Maxi says that the air cleaner is 'non-serviceable.' So, assuming that it really is serviceable:
What type of filter material is enclosed in the plastic case? Can it be removed/replaced easily?
Thanks,
Dave
Re: Maxi air cleaner
you can pop it open with a screwdriver at the seams. idoes/will open. clean it out well, and snap it back together.
Cool. I know that I could just take a look (but I'm at work) - what is the filter material? Paper, steel wool?
Thanks.
Jason Luther /
are replacement fiilter servicable? mine from the mopedwarehouse is 'welded' all of the way around.
I was looking at those - did you buy new or used? How long should one of these last, mileage-wise?
My '78 newport L (2hp) has the sides of the case apparently welded together. Should i cut it apart, or does it need to be replaced as a unit. And what else would work as a replacement. I know some peds use the filter as a restrictor for more low end, do puch's?
Ben Van Zoest /
Just soak it in hot water w/ dishwash soap like Joy, rinse and dry. Looks like a brillo pad inside. Worked 4 me ok.
There is a metal screen inside the houseling. I cleaned mine using good ole simple green. Gave it a shake and let it sit. after cleaning I even had to re-jet.
