79 hobbit carb problems ?
I am having all sort of trouble with my sons moped, As far as keeping it running. I have taken the motor off to get to the carb and cleaned it and put it all back together. It took right off running for about 5 minutes then it died again. It will idle all day long, but once I give it some gas it bogs out. If I let off the gas, it is fine. Go figure. If anybody can give me an idea, that would be GREAT!!! I have a listing looking for a carb right now, if someone has one let me know.
Thanks
Rick
Re: 79 hobbit carb problems ?
A common mistake when working on these carbs is to reassemble them incorrectly. The float bowl should go on with the drain to the right side. Check this first.
I was wondering if there was a difference because it goes on both ways. Thanks for the advice.
Rick
There's always Fred's Guide if that doesn't work.l
isn't it a pain to remove the whole frame to get to the carb
If it is difficult, you are doing it the hard way...there is a very easy way. I should know, I have done it many times!
i just removed 2 cables and 3 bolts to get to the carb
I took off 3 bolts, decomp cable and unhooked the wires running from the motor. but when you do this the frame wants to flex when taking it off and putting it back on. I put zip ties on the frame to keep it from flexing.
Well tell me what is it.
