what do you use to clean a semi rusted gas tank
help me
Re: help me
i use some small rocks...like gravel...
not too much of them...
a little gaz in it
and shake it as hell
works well for me
g.b.
Re: help me
rocks in a gas tank i dont know sounds sketchy
Re: help me
http://mopedarmy.com/forums/discuss/read.php?f=1&i=101700&t=101679
search "rusted gastank" there's a ton of info on this subject.
Re: help me
Paul -
You should be canonized!
I can't believe that you have the patience to do searches for so many people.
There is a 'Search' option at the top of the page that no one seems to use.
Re: help me
i did this- and it worked
swish some BB's around in the tank with some kerosene
then flush it out with water, repeat- then flush it out a coupel times
nick
Re: help me
Use limestone rocks, as johnnyd said. Limestone is a natural filter of nature. I have used it a bunch when cleaning out gas tanks. It works great. Just be sure you get all the rocks out. Either that or there is some kind of stuff you can buy that is called "??Kreme??" or something like that. It is a 3 step stuff. I hear it works great.
Re: help me
i know it, but no one seems to use it....
Re: help me
don't use rocks!
go to home depot or whatever, get some small screws, like 1 inch or smaller, dump em in wit some gas, shake it up.
Re: help me
ryan -
Why would screws be better than roxks?
Just curious.
Re: help me
i just want to know how to go about all this i mean how do i get them out and stuff - thanx
Re: help me
if its a built in tank, your options are kind of limited. unless you can shake 120lbs over your head. if its only a little rusted, live with it and get an in-line fuel filter from a lawn mower place.-jason
Re: help me
yes. if it is removable, DON'T USE ROCKS OR CHAIN THESE GUYS ARE RETARDED. haha nah I'm joking guys.
but really, use some really small guage chain. that way you can't accidentally leave one in there.
and don't flush the tank with water.
Re: help me
This works well...get some naval jelly clean up the rust inside..then buy some neutralizer. and flip the moped upside down and back around to coat it. the rust will be coved in a hard surface that is harmless to gasoline. ( I have had to do this procedure 3 time on 3 old bikes)
Re: help me
is there any type of liquid like CREAM that works good and oh ya its a puch maxi were talking about so no i cant take off the tank
Re: help me
Yes...Naval jelly, and ask someone for a rust neutralizer
Re: help me
how do you get it out of the tank
Re: help me
I used Naval Jelly on some rusted parts on my outboard and it worked awesome. Never heard of using rocks or screws or chains, but that would probably work too. It would just be hard to get them out of the tank. I think you can clean up the Naval Jelly with gas. Make sure you where gloves. Its nasty stuff!!
Re: help me
I just checked my Navel Jelly jar and it says to rinse it out with water. I guess if you use the Navel Jelly Rust Neutralizer the water would'nt harm anything. I am not really sure.
Jeff
