Re: riverside throttle stuck???
Jason Luther /
you have a dellorto carb. which are on a million other peds. the end of the cable has a little nub on it that connects to the carb 'slide' #6590 on picture.it should not go through the spring! so twisting the throttle grip, pulls the cable and thus lifts that slide up, letting in more air. if your carb is super dirty, or the throttle is super dirty, the slide might not return properly. also your cable may just need to be adjusted. us the threaded sleave #6650 to adjust the tension, or there may be a similar thing at the throttle. make any sense?-jason
