Cut Out Switch
Hi
I think this is where this question should be anyways
I am thinking about getting a MOT on my Puch Maxi (i am going to be 16 in january) and i need a few things done, one of them is a cut out switch but as i live in the uk i cant by a puch cut of switch on e-bay so
Could you be able to make one?
Could you by any cut out switch (what ones?)
Anyways this is a bit far fetch but can anyone help?
Plus do you need a working speed-o to pass a UK MOT
Thanks Martin
Re: Cut Out Switch
Ben Van Zoest /
Any motosport store will have a cut-off switch, push type to interupt, (chassis ground) the coil supply voltage. Just go see how diff. mfg do it and order the part.
Re: Cut Out Switch
Martin Read /
I dont understand so any puch type cut off switch will work and how do i connect it up to my puch maxi?
Would this cut out switch work?
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&category=25626&item=7927364581&rd=1&ssPageName=WDVW
Re: Cut Out Switch
i have a puch MKII kill switch
does not have a mount though
Re: Cut Out Switch
Martin Read /
what you are selling it?
Re: Cut Out Switch
Martin Read /
Is there only one wire coming from a puch kill switch?
Anyone?
Re: Cut Out Switch
Jason Luther /
you can wire a light switch ffrom your house if you want. go to any electronics store (do they have radioshack in uk?) get a small switch rated for 6 volts and hook it up. or order any switch from any moped on ebay.-jason
Re: Cut Out Switch
Martin Read /
and when i do that where do i hook it up to (when i brought my moped there wasnt a kill switch on and i dont know where one goes)
Can any one help?
