Re: Honda Spree won't run- Flooded
Don Pflueger /
your starter motor is located on the bottom of the engine, towards the front, between the engine and the frame. if the water got high enough in your garage, i'm sure the starter got drenched.its probably all rusty inside. you need to take it off, tear it apart, clean it up, and grease the shaft ends. it should be fine then.
