your starter motor is located on the bottom of the engine, towards the front, between the engine and the frame. if the water got high enough in your garage, i'm sure the starter got drenched.its probably all rusty inside. you need to take it off, tear it apart, clean it up, and grease the shaft ends. it should be fine then.
Re: Honda Spree won't run- Flooded
Subject | Written By | Posted |
Honda Spree won't run- FloodedTopic by: Matt Mautz | Matt Mautz | 10/14/04 05:29PM |
Re: Honda Spree won't run- FloodedRe: Steve B | Steve B | 10/14/04 09:02PM |
Re: Honda Spree won't run- FloodedRe: Don Pflueger | Don Pflueger | 10/14/04 10:47PM |
