Whats the difference between rebuilding a carb and cleaning it?
carb cleaning vs rebuild?
Re: carb cleaning vs rebuild?
rebuilding it means you are replacing old worn or faulty parts such as needle valves and gaskets. cleaning means just that, cleaning.
where can those small parts be bought?
mopedwarehouse.com, themopedjunkyard.com, and others.
depends on what bike, and model carb you have.
what are some major signs that a carb needs a rebuild?
that it doesn't work
on these engines, it usually wont start, or it wont idle. or acts like it is getting too much air.
Some carbs no matter how well you try to clean them, cannot be salvaged. Particularly, ones that have a lot of white crusty, powdery materials in them. I have found that even the best carb cleaner cannot get that white stuff out. Even if you manage to remove the white stuff, the pot metal is usually eaten away. The only way I have found to remove that stuff is to use a dremel with a wire wheel attachment and grind the stuff off.
ive actually boiled some in a pot of water on my stove to loosen up hardened deposits.
wow I never thought of that. is that safe?
why wouldnt it be safe? the carb isnt full of gas anymore. as long as you dont leave it in there boiling for hours nothing can melt. ive done this with 30 or more carbs and they work fine.
but what would that do to the gaskets?
Remove the gaskets. Only boil metal parts. The carbs have to be taken completely apart to take off all deposits and/or to be completely cleaned anyway.
you have the carb taken apart. there wont beany gaskets, just the carb body.
