Removing Maxi exhaust baffle
Is there some trick to removing the exhaust baffle from the main tube of a Maxi exhaust? I removed the nut, the tube and the small diameter tube that inserts into the baffle, but I don't seem a way to loosen the baffle itself. There's lots of soot in there - could it be frozen in place?
Thanks,
Dave
Re: Removing Maxi exhaust baffle
See Ya Moped Army /
Take a broom handle and insert it through the front of the muffler. Then, pop the broom handle on the ground and the baffle willcome right out the back end.
mine does not come out cuz the outer pipe is bent towards the middle
its been that way when i got it so i wasnever able to clean it well
Ben Van Zoest /
I heard guys saying heat it with a torch, my guess is blow the flame in the small end and cook her well. Than tap the big end on the floor...
i loosend both my nuts and mine wouldnt come out
well i rode around not knowing i didnt put the nuts back and then eventually the heat and vibration made it come right out.
dont do that on a maxi pipe! i did.. and partially melted the end of the baffle...
See Ya Moped Army /
Unless the pipe is crushed, a broom handle will pop it out everytime.
Jason Luther /
or just grab it with channel locks. but mopedlars cure is better it sounds.-jason
