puch clutch start arm ??
Troy Brown /
i am having a hard time getting the clutch start arm back on to the return spring.anybody know how to get it back on the right way??
Re: puch clutch start arm ??
Ben Van Zoest /
Once made a tool for that, let me look 4 it. Will post a pic if found.
Troy Brown /
tbrd OP
thanks .it looks like i can push the spring back, with a screwdriver, but i will wait for a few more replys.
Troy Brown /
tbrd OP
anybody know how to get this thing on??
Ben Van Zoest /
Can't find that darn special plier must have left somewhere on a job. Sorry, I would have loaned out.
Troy Brown /
tbrd OP
thanks for the effort Bernard. i will try to push it over with a screwdriver.
Bernard, could you describe how that tool worked or looked like? I guess I'll go try to get it with a screwdriver in the meantime.
Ben Van Zoest /
Made from a piece of flat bar stock, two petruding pins to lever the arm. Also used to preload a tension arm on a robot.
I think what happened is the tool and two 3mm wide cone wrenches were removed from my toolkit at a job at a Detroit plastic factory. People like weird stuff.
