Somebody can tell me how can I clean my carb (mikcarb) and the engine (2 stroke)?
carb cleaning
Re: carb cleaning
take it apart, spray it down good with carb cleaner, poke wire thru every hole you can find in the carb body and its parts, spray carb cleaner thru the holes, put it back together.
Re: carb cleaning
should you let the carb soak in something if you have time?
Re: carb cleaning
it never hurts to soak them in carb cleaner if you can. but never more than 15 minutes. wash it thoroughly with solvent or water after soaking it to neutralize the acid in the carb cleaner. most auto parts stores sell carb cleaner in quart size containers up to 5 gallons.
