Re: Tomos Brake Light
Don Pflueger /
well, if the brake light doesnt work intermittently, then the problem is somewhere from the tail light bulb socket up into thewire harness. but if the brake light is intermittent, then i would check the ground wire where it meets the fender or the frame. that is a common problem area and both lights share thesame ground. but if only one light is having problems, then the actual problem is somewhere at or before the light socket.
