tomos transmission HELP CLUELESS
Ryan Nealy /
wow I'm so clueless. I have no clue how to fix this stupid transmission. I have an a35 2003 tomos and I can't figure out what is wrong.
the clutches are fine.
I just replaced the middle gear cluster. everything is fine I checked it out.
I assume that that bango shaped clip on the pedal shaft goes into the open spot on the crank.
but I did that and it still doesn't work.
the pedal either slips when you try to ride it like a bike or slips when you try to start it. it's different everytime.
