tomos transmission HELP CLUELESS
wow I'm so clueless. I have no clue how to fix this stupid transmission. I have an a35 2003 tomos and I can't figure out what is wrong.
the clutches are fine.
I just replaced the middle gear cluster. everything is fine I checked it out.
I assume that that bango shaped clip on the pedal shaft goes into the open spot on the crank.
but I did that and it still doesn't work.
the pedal either slips when you try to ride it like a bike or slips when you try to start it. it's different everytime.
Re: tomos transmission HELP CLUELESS
Don Pflueger /
look at the breakdowns on www.mopedriders.org under the moped repair section and go thru your tranny very thoroughly. you may havea shim in the wrong spot, or something is sheared.
or look in my profile
