Delorto carb drain screw gasket
A while back I noticed my carb was leaking a bit more than usual. Today I took it apart, and the little rubber gasket that goes over the drain screw at the bottom of the float bowl totally disintegrated. I made a little temporary gasket out of cardboard, and it leaks a lot less now.
But it still does leak. Anyone know where I can get a suitable replacement for this little part?
Re: Delorto carb drain screw gasket
Ben Van Zoest /
Any good hardware or yard machine shop...
What exactly would I look for? Sheets of rubber gasket material? I'd like to get something that wont disintegrate in gas quite so quickly as the last one did.
Don Pflueger /
any hardwarestore. just geta rubber o'ring that fits over the screw.
