a couple of tomos problems
I have a 95' tomos sprint, i was starting it up, had the choke down and hit the throttle and the throttle cable snapped, i was wondering if that is hard to fixand where i can get a new one? also, when i accelerate, it makes a loud noise but when it hits second gear the noise goes away. Any suggestions!
Re: a couple of tomos problems
Don Pflueger /
www.ikesbikes.com has the throttle cable as well as www.mopedwarehouse.com. what kind of noise?
its a high pitched noise coming from the motor i think, someone told me it might be the clutch shoes, not sure.
thanks
Don Pflueger /
hows your oil level? and what does your oil look like? some early versions of the a35 had a problem with a circlip popping off and causing grinding noise until enough of the case was gone that the shaft came out of place, then things would get ugly.
