Re: 83 Honda PA50-II help!
Richard Riedling Ii /
To be clear, the drain screw on the bottom of the bowl should be on the SAME side as the choke lever?? (The Right side as you sit on the moped)..
I think my emulsion tube is causing my problem. I'm going to take the carb back apart, make sure I have the bowl oriented properly, and "push" that tube out from under the main jet.
I'll post some results tomorrow.
Thanks!
