here is my setup, ive got a 1980 puch maxi with the 70cc airsal kit, stock delotoro carb, and a biturbo pipe. im currently running a 68 jet but its too big any suggestions on what size?
buy a #66, 64. that should get you in the ballpark.
Sounds like you may not have your airbox open enough for the #68 jet. Before I would be doing anything, I'd make sure the airbox isn't too restrictive.
Paul is right,though, if you're getting enough air. don-ohio
i have no filter so i know its no air restriction. its gotta be the jet because before i rebuilt the motor it ran fine but as i rebuilt the motor i resealed everything and it started doing this.
