Puch exhaust leak
Matthew Libhart /
Hello,
I have a new performance exhaust for my Puch Maxi 1speed. Problem is that the angle of the flange that attaches to the cylinder is off by about 1 degree so that when attached, there's a small space at the back of flange that isn't flush with the gasket, so it leaks. I'm wondering if my only solution is to try to heat the pipe up enough to bend it or if I could use a "gasket in a tube" type product. Any advice is appreciated.
Thanks.
Re: Puch exhaust leak
i wouldn't. try doubling up on your your exhaust gasket. it might solve it.
