Re: tomos headlight contact corrosion--too much ju
Don Pflueger /
it could be because your drawing more amps than those connectors are designed to handle. tomos only has a 35w charging system and you are running a 60w bulb. you can get dialectric grease from radio shack and coat the terminals.that will slow the corrosion down. regular grease wont work.
