vespa bravo
I have a vespa bravo, circa 1976 - cleaned gas tank, new fuel lines, good spark and compression - but engine runs inconsistently - seems to be starving for air. When the air filter is taken off it runs nicely. Seems as though the mixture is not correct - too much fuel to air. Carburetor is clean - jets and float seem ok - any ideas?
thanks
Ron
Re: vespa bravo
Anthony Castellanos /
punch some holes in the air box
Re: vespa bravo
Did you clean the Idle jet?
Re: vespa bravo
thanks
it is on my list of potential remedies
Re: vespa bravo
well - I have cleaned the main jet and messed around with the idle screw - help me out and describe what I should be looking at for the idle jet.
thanks very much
Ron
Re: vespa bravo
Dude, I just posted a picture of it with a circle around it!
Remove your carb, remove the plastic insert collar that fits over the intake manifold pipe (it may come off and stay on the pipe when you remove the carb).
Once that is removed look at the pic I posted. Clean the hole with a pin, needle or very thin wire, carb cleaner alone WON'T clean it. After to you clean out the hole with a pin or something then use carb cleaner or WD40 and then blow it out with compressed air.
Re: vespa bravo
the plastic sleeve is actually stuck in my carb. is there an easy way to get it out?
Re: vespa bravo
Bruce Wilkinson /
The sleeve may not have to come out. Can you see the hole that Zippy circled in his picture ? If you can then poke a tiny wire in it to clear any debris and clean with carb cleaner and blast it out with compressed air. bruce
Re: vespa bravo
thanks Zippy
I think I know what you are talking about - I am new at this so allow me a stupid question - where do I see the photo that you posted.
Ron
Re: vespa bravo
Click on this link and then look where it says "Attachment:" and then click on the link, you should see the pic.
http://mopedarmy.com/forums/discuss/6/9889/9885/
Re: vespa bravo
Zippy
thanks again - now I can see! - I will give it a try.
thanks again for your help.
Re: vespa bravo
You're welcome and good luck.
